Having difficulty getting a good finish using WB gloss (Leyland Trade Acrylic Gloss - pink tin) on flush doors. I've done the skirtings, architrave and 250mm deep window ledges with the stuff all quite nicely, what good paint I thought, but now it comes to the doors it is Hell! What is the trick??
All bare wood or MDF, primed and undercoated with WB undercoat, multiple coats sanding between them. Doors laid flat with all hardware removed and looking good. On with the gloss - initially using a 2" brush (B&Q basic synthetic) as used on the rest, but couldn't get the paint on fast enough to lay off before it was too dry. The result was a right mess. Then tried a sponge mini roller but the result didn't look glossy. Sand down and start again this time using an old 4" bristle brush (used to do emulsioning), slapped on the gloss but lots of brush marks and small air bubbles that dry like craters. Attempt to lay off and remove the bubbles was disaster.
I have 4 flush doors to do. I figure I need the right brush and work quicker unless there is something else I can do that will help. What size brush is best? Advice please, how best to apply the paint I have?
