Are these bricks rejects?
I'm not expecting bathroom tiles standard from engineering bricks
You can expect decent bricks and colouration etc when you buy best (Class A). With class B's - not so much. It even states as such in the literature.
I'd never finish a wall with class B's.
Wrong. The Class is the strength rating, not a quality grade.
Class B shouldn't look any worse than Class A.
Where's this literature that you think states otherwise?
You found that "literature" yet?
Of course you haven't, you made it up.
Description
This Wienerberger Terca 65mm Class B Perforated Engineering Red Brick is manufactured to be the ideal choice for applications requiring strength and resistance. Measuring 215x102.5x65mm with a compressive strength of 75 N/mm2, it conforms to BS EN 771-1 standards.
Suitable for retaining walls, pavements, foundations, damp-proof courses, groundworks, manholes and sewers, these smooth-textured, uniform red wirecut bricks are not intended for aesthetic applications such as exterior facing walls.
Read more.
Quite. From that...
Does Class A look better than Class B?
No performance class guarantees a better visual finish. Engineering bricks are primarily manufactured for technical properties, and appearance can vary.
Noseall talking rubbish with great authority as normal, then having a tantrum when it's obvious he's wrong.
Glad you posted that.
"....Unlike a facing brick, this product is valued for its performance rather than its appearance..."
"...This brick is not intended for decorative appearance..."
" engineering bricks are manufactured for performance not appearance. Expect variation in texture, colour and finish..."
Dear me. Squirm wriggle strop.
All engineering bricks are lower grade than facing bricks, you're stating the bleeding obvious.
You said that Class B are worse looking than Class A, which is complete rubbish and you now know it, you've learnt this just today from those who actually know things.
You promised "literature" that stated your wonky view. Did your dog eat it?
Those Class B bricks I got from Brickhunter are absolutely A-grade lovely in appearance.
They're very variable between brands. But I'd say that the ones I got at first weren't really suitable for anything. I doubt they'd be frostproof with all those cracks, and I'd be worried they'd crumble into the drain if used in an inspection chamber.
I'll stick to Brickhunter in future, only use the local suppliers for sand and gravel.
err....
:cool:
From your mates link....
Keep trolling Ivor.
Sad. Really sad. Short of work I assume. Not surprising given his attitude and lack of knowledge.
Anyone can buy a second hand van and call themselves a builder. As shown here.
