The whole concept in the first place - having it heating your house when you are not in it.
Quite the opposite, I want to not be heating parts of the house that are not occupied.
Three letters for youQuite the opposite, I want to not be heating parts of the house that are not occupied.
Yeh I pop the heating on when I get in. By the time I have my coat and shoes off or whatever faff that I faff on my return then the rads are hot and job done.That sounds like a contradiction?
Not heating an empty house and not pre -warming, so returning to a cold house ?
TRV
How will you stop the unheated rooms from sucking the heat out of the heated rooms? This is something that people tend to forget about and then wonder why the heating is on more often than expected, the few "on" heat sources are trying to heat the whole house.Quite the opposite, I want to not be heating parts of the house that are not occupied.
I've said that on numerous occasions. Heat loss calculations are done which assume a certain heat input from neighbouring rooms, depending on their location. I'm not a fan of micromanaging things, particularly for that reason.How will you stop the unheated rooms from sucking the heat out of the heated rooms? This is something that people tend to forget about and then wonder why the heating is on more often than expected, the few "on" heat sources are trying to heat the whole house.
closing the doors doesn't stop all heat loss, but it reduces it.How will you stop the unheated rooms from sucking the heat out of the heated rooms? This is something that people tend to forget about and then wonder why the heating is on more often than expected, the few "on" heat sources are trying to heat the whole house.
the current should never exceed target on a cold day, well maybe in theory, but in practice, the sun would cause living room to overheat, but nowhere near as bad as when using mechanical TRV heads. The boiler would modulate, so radiators would just remain warm, and all worked well.wish i had a quid for everytime i have pointed this out to people over the yearsHow will you stop the unheated rooms from sucking the heat out of the heated rooms? This is something that people tend to forget about and then wonder why the heating is on more often than expected, the few "on" heat sources are trying to heat the whole house.
This is true to an extent, but it is limited to what extent. I did notice with a semi-detached house, when the neighbour moved out, our heating bill went up, as party wall not well insulated.How will you stop the unheated rooms from sucking the heat out of the heated rooms? This is something that people tend to forget about and then wonder why the heating is on more often than expected, the few "on" heat sources are trying to heat the whole house.
looks good, but it takes no account of energy transferred room to room, it shows how the bottom of the radiator monitors temperature of return air, so the TRV is likely in the best place to monitor the whole room.
but in real life, place thermometers around the room, and it quickly becomes clear, it is not that simple, we get a cool zone around the windows, if we don't circulate the air too much, specially with curtains drawn.
Yes, modulating boilers with appropriate controls do that easily.sure there are some, but failed to find them, so the question is, when used to produce a fraction of their rating can gas or oil boiler run in an efficient way?
