A test was carried out & a few points made.
One point was High resistance detected between ring final circuit protective conductors
I was advised one of the sockets would have a loose wire in the terminal hole or the screw has been screwed down partially on the wire & its plastic insulation.
He said he would need to unscrew every socket & look, 2/3 hours work.
Seems excessive time 2/3 hours as there isn't many sockets at all
Is there a tool i can buy to plug in each socket to advise me which socket it is.
I can then secure the screw correctly.
I'm capable of changing sockets no problem so just looking to go straight to the socket in question & rectify it.
The reading figure was 0.91
