I have built a shower cubicle and the frame that the shower door fits in to is made of wood and the other 3 walls are plastered walls with the floor being concrete and a small wet room drain fitted. The frame is about 120mm wide on all four sides of the shower door with the bottom also forming a barrier to stop the water from the shower floor running out of the cubicle. the timber used is solid 120mm x 50mm.
What I wanted advice on was what sort of adhesive to use to tile to the wooden frame and any preparation I should do? Most adhesives that I see for use on wood are for floor tiles, could that still be used for wall tiles ?
