ACCENTA6 - Tamper
  • Thread starter Thread starter cpl
  • Start date Start date
cpl
5 Oct 2007
I have an Accenta6 alarm. The main box is in the upstairs airing cupboard. This cupboard backs onto the en-suite shower. I had the shower replaced yesterday, the guy who did it said he had trouble getting the old shower off the wall, the alarm unit is directly behind this shower. Obviously the vibrations were felt by the alarm and it has gone into "tamper" mode. The remote key pad does not respond to any numbers being typed in the only led light showing other than the green "day" and the red "power" is the red "tamper".
Anyone has any idea on how to unlock the system?
Just tried 1234. No good. As I said earlier, the keypad is effectively "dead". Normally you get an audible beep when you enter a number. Currently there is no sound.
Appreciate the response anyway.
Find the tamper fault, fix it and the system will reset. It will stay locked up until you fix the fault.
Its probably configured to require the engineers code before you can re-instate it ...... Time to look for the alarm paperwork me thinks :o
i dont think this panel has a microswitch, i think its a switch with a spring, most panles will let the user clear the tamper, providing the condition it self is cleared
Makes no odds really, if three presses of the reset button isn't doing anything, you need to go in to the engineers menu to reset it...... The engineers code could pretty much be anything :(
I've fitted hundreds of these ...... Theys brill :lol:
& why they changed all the menus round when they re-badged it a G3 I'm dammed if I know :?:
How do you find the tamper fault?
Take the lid off the main panel in the airing cupboard. Check for any loose connections on the circuit board (beware, there are mains voltages inside the control unit around the mains terminal block and transformer, so don't go around there!)
If all appears well, close the lid and make sure you hear the tamper spring close. Press reset and it should go back into day mode.
Scott, thanks very much it worked. I had previously tried taking off the cover but instead of pressing the tamper button I was entering either the exit code or the engineers code.
Thanks to eveyone who tried to help, it has saved me a call out fee.
