Silent extractor fan...
Have alook at the Icon Airflowlow; low db & diffrent flow ratings, it also has a natty automatic iris shutter that keeps out the draughts when not in use. I have 3 fitted in our house, bathrooms & a utility; you can either wire them as supplied (just switched) or fit different, click in modules, timer, pull cord, humidity etc.
Hi y'all.
I found this recently, its a new product, comes well recommended.
At 26.5 dB(A) and with rubber motor mounts its the quietest bathroom fan so far.
26db at 3m?
Are many bathrooms that wide?
I thought db at 1m was a typical measure, so make sure that you are comparing like-for-like
Edit
Yeah, yeah I know .... the OP has probably fitted it by now :roll:
No actually, the industry standard is at 3 meters, though some state at 1 meters..
In-line fan in loft suspended from springs [to minimise vibration] works well, have two above my shower room.
Hi foxhole,
Your idea sounds good, I have an inline extractor fan which I find a bit noisy (maybe should have gone for 10cm rather than 12.5...) Would be grateful for any tips on which springs to buy and how to suspend the fan. The seller also suggested wrapping in loft insulation to keep the noise down but I was worries this might make it overheat.
Cheers,
Steve
