windows vista dvd damaged :(
2 Oct 2004
Reinstalling vista dvd drive jammed marking dvd disc :(
Drive not reading dvd ..need new drive and vista ultimate disc :shock:
Need vista ultimate oem dvd , where and how ?
New dvd writer samsung lg Philips nec etc upto £20 preferences ?
TIA
Can you not just borrow a disk from someone else with the same OS or ask around nicely and get somebody to run you a copy off? The important bit is the key which is on a sticker which should be attached to your machine which you can use to re-activate your software. I take it that you need the 32bit version?
Try to polish out the mark on the DVD. Try Brasso or PlastX
Scarum Colgate toothpaste followed by brasso (in tin with wadding-duraglit) gives mirror finish :o
Can you not just borrow a disk from someone else.......... The important bit is the key which is on a sticker which should be attached to your machine which you can use to re-activate your software. I take it that you need the 32bit version?
Spark123 any vista 32bit disc will do it has all versions on :D
Dont enter product key during install,click next gives all versions on dvd!
I used a cd repair company on a playstation disk. brought it up like new. cant remember the name of the company but similar to this one.
http://www.cd-repair.co.uk/[/QUOTE]
scottster the disc has 3 very fine cracks in the centre around spindle hole,hard to see ! Followed the diy section in your link for disc repair .
Disc imaging runs to 30% then aborts :( .New DVD writer £15 :)
Thankyou Scarum Spark123 and scottster
