Zanussi/Electrolux Model DE6854 not heating
8 Apr 2007
Lancashire
I have had the machine apart, its filling fine and going through a cycle.It looks quite healthy inside but the white stuff in the temp sensor has gaps in it and the water is not heating.Should I replace the sensor first before moving onto the heater element or is it more likely to be the pcb ?
Did you find out what was wrong with your dishwasher, as I've the same problem and it's not the PCB dry joint, thanks.
Cowan
Hi
Tried heater first but subsequently found it was the temperature sensor.
