Hi, just moved into a house which has an outside PIR light that doesn't work. I have tested the lamp by putting it into an internal spot set-up and it is working fine. The switch is located directly behind the light in the inside passage way. The switch is a two gang as the second switch works the passage way light. There are four red wires on the back of the switch plate as follows.
1) Red connected to "A" (passage switch)
2) Red looped from "A" to R1 of PIR sensor light switch
3) Red connected A1 of passage switch
4) Red connected to "B" of PIR sensor light switch
The connections at the lamp fittings are correct and secure. They are
earth to earth
neutral to neutral
live to L
LS has no connection
Any help appreciated
earth to earth
neutral to neutral
live to L
