Do you consider that "metal strips" meet the provisions of 522-06-06 (iii)?kevnurse said:If you don't have the safety distance you must get some metal strips to protect the cable.
If I can get it to 50mm softus, what should I use for protection?
Hammondo said:Unsure of what I or anyone else would ever screw into a skirting board, but thanks anyway!!
telephone sockets, cable television points, network points etc etc..... as well as the " ooh, it's comming away from the wall there, I'll just put an extra nail / screw in to fix it back on... "
as for whether or not the socket is or is not near to a door way... EVERY socket on the downstiars needs to be RCD protected as it's just as easy to run an extension lead out of a window as it is a door.. more so if you don't have a back door or don't want to leave your house open while mowing the lawns etc...
for future proofing also, EVERY socket in the house needs to be RCD protected to comply with the upcomming 17th edition regs..
Nice bit of plastic trunking run along the top of the skirting board ?
Thats what i'm thinking, but on the other side of the wall in the cupboard, with the wire passing through the wall back into the lounge at point of where i want the socket. Is this within regs anyone?
Wait till January. RCD protect the cable, as this will be acceptable if it is run shallower than 50mm & is not protected by mechanical means. Fit a plaster depth box (empty) into the skirting with a blank plate on, indicating the possibility of a horizontal or vertical cable run.
