There may be a blockage in the "U" bend at the base of the hose. The "U" bend can be unclipped and the blockage remove very easily. Do not use any undue force as most of the parts can break very easily.
The Manual can be found Here. It is a pdf file so may take a little while to download on dial-up.
There is also a section on how to remove a blockage Here.
