I have a small property in Spain. At the moment I have one radial circuit that does the sockets (and some lighting) for the whole house and one lighting circuit. Its way over the UK standard of 2.5m for 50sq. Because they use double pole MCB/RCBO's over there and my existing CU is very small I only have space to fit one more RCBO. I will use it to put in a separate circuit to the kitchen (which uses the most power) but want I want to know is whether I can safely run two radial Circuits off the same RCBO. Its not ideal i know but you would not believe the hassle involved in getting another CU fitted
