D
Deleted member 54734
samtheman1k said:However, the E10 tariffs require a single meter & thus single output.
Where is everyone getting this idea that an E10 setup is single rate or am I just getting confused??????
Economy 10 (E10) AFAIK or until somebody tells me to fit it differently (which I can't see how) is a 2RATE tariff.
The most popular E10 setup in my area is a TELEMETER (a meter with timer built in) programmed to E10's times.
A telemeter has your normal 4 ports plus 1 extra for the off peak load.
This extra port only becomes live at the set times.
The other E10 setup we fit is a 2RATE meter with a mechanical 6 arm timeclock which we set to switch at the right times.
Both setup's in this area at least will be fitted with a 3pole isolator (if there is not one on site) so with the help of a Henley for the neutral, the electrician can install the off peak CU without cutting seals.
It seems to me that you fella's are spending you hard earned cash on something that will be supplied with your E10 install?
