Hi all, when drawing domestic hot water from my Linea 24 it will be fine for a while then on some occasions will run cold. By adjusting the domestic cold suply valve situated at the right hand side at the bottom of the boiler to reduce the flow/pressure, the water will then flow consistantly hot and I can adjust the temperature with fine control of the same valve. Would this indicate that the domestic hot water flow switch located above this valve is defective or is there another fault?
Any help would be appreciated. martyok
