- Joined
- 13 Dec 2007
- Messages
- 106
- Reaction score
- 0
- Country
Hi all, Yep this is my 1st post so thought i'd introduce myself before ranting on about something of a safety issue.
I am a fully qualified electrical engineer, trained by the electricity board where I started my 5 year apprenticeship as an electrical fitter in 1990, finished that and went on to qualify as a craft engineer and then a year after that guess what - I got made redundant!
So, any project type or 'out of the ordinary' questions, feel free to message me as im used to working on anything from small electronics upto 132,000 volt systems - also im authorised to work over and above BS7671 which has caused a few heated conversations with some normal sparkies but i do try to get on with everyone
Anyway heres my rant:
I had a call this evening from someone who put lots of christmas lighting up round their house, looking very nice indeed. However guess what... the main switch in the consumer unit had melted! This was caused by the terminal screw on the incoming 25mm tail not being tightened properly.
All sorted now, changed switch over and bobs your uncle. with a constant load of 6kW of lighting (all on a green tariff) it doesnt take things long to heat up.
So always check and double check tightness of connections. A 9kW shower on for 20 mins will not cause enough heat to cause this sort of problem due to the short duration the shower is used.
A 3kW kettle definately wont (unless the connection is extremely bad)
6kW of load for 6 hours a day will cause probs on a bad connection.
When terminating conductors, especially 2.5mm inside the back of a socket, always double the copper conductors where possible. The idea is to fill the whole with as much copper as possible so that when the screw tightens, its not just pinching on the 1 strand of copper, but gripping twice the surface area, hence half the resistance
Obviously its impossible to double over larger conductors in cooker sockets etc, however in this case its good to use equipment that has two termination screws where the cable enters the terminal, and not just the one screw.
Ive had this argument with sparkys lots of times, they sometimes dont care, as long as the test results are fine (which they will be at 1st) - try again after 6 months of heavy use and you will get a big increase in resistance. - resistance = heat = hotspot = flames! This will not always trip an mcb or rcd either!
It doesnt matter who your registered with, NICEIC, Part P with the council.... its the quality of workmanship that counts. I've seen some horrendous work done by registered people so use your instinct!
if someone is not doubling conductors over then question it by all means!
I'm usually much more chilled out than this just this eve it got my back up lol!
Any questions/advice feel free to fire away!
Regards
Rich.
Regards
Rich.
