Hi
I will be using one of these junction boxes (20A version) with three 1.5mm T&E cables. I can't find a picture of the internals but it has four 'pillars' each with a tighten-down grub screw.
My question is: what is the best way to secure the cores so they make a good durable connection?
I could double over each core and then 'stack' them and tighten down the grub screw on the stack of cores.
I could twist the cores together and then tighten down the grub screw on the twisted cores.
Either way, the T&E going in to the junction box will be secured with cable clips to prevent cable movement. The junction box itself will also be screwed down.
Many thanks in advance
