3 core and earth flex - should I use both live cores?
15 Jan 2007
I'm going to hardwire my boiler into a FCU.
The plug has already been cut off and the flex is 3 core and earth. How should this be wired? I assuming that as it has the extra core it should be used?
I'm also presumming that it's OK to use a 13amp FCU if I change the fuse to a 3amp?
There is at least one crucial question you should be asking yourself. The first is,
How was the plug wired up?
:D Unfortuately it had been taken off before I got to it.
I've had a look in the boiler manual and when referring to the electrical installation it only mentions a live (brown or red) and a neutral (black or blue) connections. There is no mention of anything else apart from the earth.
Therefore I thinking brown for live, blue for neutral and leave the black redundant.
With a combi boiler you only need a live n and earth 3 wires
Other boilers may need 4 wires 4 a pump over run
you should have a room stat wired to the boiler to be part p
If the black is redundant, it good practice is for it to be grounded.
Why can't you access the other end of the flex to see how it has been terminated?
There is a room stat in the hallway.
The instructions state
"The connection to the mains nust either be: A 3amp fused 3 pin plug and unswitched socket outlet or a double pole isolator with a contact seperation of 3mm in both poles and supplying the appliance and controls only."
I take it a switched FCU is classed as a DP isolator?
Looking on screwfix it definately says that the switched FCU is double pole
