[/b] IN AUGUST I HAD A RAVENHEAT CSI 85T INSTALLED. AT FIRST IT SEEMED TO WORK OK BUT OCCASIONALLY THE BOILER "FLAME OUT LIGHT" WOULD COME ON, INDICATING THAT THE BOILER HAD FAILED TO START. AS TIME WENT ON, THE "FLAME OUT " LIGHT WAS COMING ON MORE FREQUENTLY. THIS WAS IRRESPECTIVE OF WETHER HOT WATER OR CENTRAL HEATING WAS BEING CALLED FOR. THE CORGI PLUMBER CHECKED IT AND SAID THE FAN WAS RUNNING BUT THE differential PRESSURE SWITCH WAS NOT MAKING AND CONSEQUENTLY THE BOILER WOULD NOT FIRE UP. HE CHANGED THE SWITCH BUT THE PROBLEM PERSISTED AND PROGRESSIVELY GOT WORSE. AFTER CHECKING WATER AND GAS PRESSURE WHICH WERE OK THE PLUMBER DECIDED TO CHANGE THE BOILER. NEW BOILER, SAME PROBLEM!!
HE NOW TELLS ME THE PROBLEM IS THE FLUE.
HAS ANYONE HAD THIS PROBLEM? IF SO WHAT WAS WRONG AND HOW DID YOU FIX IT. I WOULD REALLY APPRECIATE SOME HELP ON THIS ONE.
