Problem: my vorkera flowmatic 20/80 Rs has started to play up!
it has developed two main problems.
1.firstly, the water pressure drops to 0 bar everytime I use the central heating. I have to top it up to 1.5 bar with the water pressure tap under the boiler, which is very annoying eveytime I use the gch. this doesn't happen when the boiler is used for domestic hot water supply, IT ONLY happens when the central heating is used.
The pressure takes around 40 mins after the central heating has been switched off to drop to 0 Bar.
The pressure remains at 1.5 bar with no problem for days, even weeks if the GCH is never switched on.
2. the other problem (which is even more annoying)
when taking a shower, the hot water runs hot for a couple of minutes, then runs cold for a few minutes, then hot again, then cold, this cycle repeats all the time, so your stood in the shower waiting for the water to run hot again. my women is giving me serious grief about it!
I know when the water runs cold, the boiler isn't flaming up in the heat exchange. i can just see the pilot light lit.
I have had people out to the boiler before, I think they took out something, blew it and put it back in, and it worked.
(I cant think what it was called) - think it was a venturi or (means nothing probably)
I know the boiler is an older model and I have read previous posts on the forum and people say the boiler is a workhorse and gives reasonable service if its serviced regular.
I had someone service it last year when he change a diaphram.
could anyone give me an idea what maybe wrong?
I have someone coming to look at it tommorrow.
don't want him to scrap the boiler if it's nothing mega serious, is it worth repairing?
