- Joined
- 31 Dec 2007
- Messages
- 109
- Reaction score
- 0
- Country
how old coud this arrangement be?
60's or early 70's
EDIT: Sorry rubber there as well so could be even earlier
The junction box is the right style for late 60s / 70s.
The grey cable looks to be heading on for 40 years old to me.
It looks like plastic twin with no CPC.
Circuit Protective Conductor (sometimes wrongly referred to as an earth wire)
The bare connecter blocks was quite common for low volt tran connections till mole boxes came out.
consumer done over";p="810902 said:The bare connecter blocks was quite common for low volt tran connections till mole boxes came out.
NOT saying it was right, in pubs and shops, this is often found where people too lazy to fit j/b, with the mole box it seems to have less common recently.
Not sure but was it not the 16th regs that said all conneections had to be enclosed
That looks 90s though, other stuff 60 70s
Photo of mains and head and inside cu might date itTrying to get an approx. age of this installation
Probably before 1966 - the twin cable was 3/029, which was usually manufactured without an earth conductor, as it was exclusively used in lighting circuits, which never needed an earth until 1966. The cores of the cable will be three tinned copper strands each of 0.029 inches in diameter - any older spark will confirm this fact.![]()
