Can somebody give me piece of mind re FCU and spur please?
5 Feb 2008
Hi folks,
I have read this sevral times but just to ensure tht I am correct please can someone confirm the following?;
I want to add some extra sockets in my garage. The problem is, the exisitng double socket is already a spur off the a main socket (the other side of the wall as it was an extension before I moved in).
I want to add some double sockets primarily to run a freezer (which will always be on) and then to run a couple of other items on an ad hoc basis e.g. tumble dryer, extension lead for power washer, xbox , tv.
Eventually I want to get it finished off into a proper utillity room at which point I will get a ring main put in by a sparky.
To tide me through, if I put a 13amp fused connection unit BEFORE the existing spur socket that has been there longer then me, am i then safe to run some extra sockets off as an interim measure?
Many thanks :)
It will be safe, but you won't like what might happen to a 13A fuse when loaded with a freezer and a T/D....
It's possible, not certain, don't know how likely.
Why not plug a multiway trailing socket in, with a 13A fuse, run the freezer and T/D off it, and see what happens?
ban all sheds -- thanks for your advice; that method seems to be fine.
On a seperate note, will it make any difference, if i install a FSU then a double socket that will serve the tumble dryer, then another 13amp FSU before the socket that controlls the freezer or is this just a waste of time?
sorry if the question is daft :roll:
Draw that on paper, and look to see which loads will have their current going through the first FCU.
tumble dryer for the first fsu (which obvioulsy wont be used at all times), then freezer on the 2nd which sadly has to swallow power 24/7
