17th Edition - RCD requirements and concealled cables
Anyone know the name of the metal stuff shown in use, within the PE mag
On the article about this subject
Didn't know they'd taken split-con off the list, and didn't think about the sizes it's available in... :oops:
How much does BS8436 cable cost compared to T/E?
flexible steel conduit
Thought it looked too small for that.
Will have to look again
Looked more like that thick metal covered flex.
Like you said though, that Kopex has to have internal earth, so would not think that would count.
doing my 17th edition upgrade next tuesday. From what I have read so far, most of it is just about moving bits of the regs around to suit europe with some add ons about mobile theme parks and markets and temporary installations. (I love europe since the introduction of temporary charging of VAT in the 70's)
Well good luck, if that's all you know.
And why do you regard Europe as something separate from us?
Securespark; Why is is called a "Nottingham" board?
Curious as I was born there thats all. :oops:
This issue with depth without protection, are they simply trying to get us to use the oval pvc conduit?
Gives about as much protection as a condom in a needle factory.
I saw a drill this week with built in stud/pipe/cable locator 8)
I am of the opinion that any lighting on RCD protection is a bad idea trips and falls etc.
Would love to see how some of the fellas are doing their own emergency lighting in their houses, my wife would have a dicky if I installed a lovely green and white exit sign above the front door :lol:
PVC is no good, the part of the requrement referred to by Pensdown referrs tor an earthed conduit complying with BS EN 61386 and satisfying the requirements of the regulations (BS7671:2008) for a protective conductor.
maybe the european style switching (auto alimentation???) with elv switch drops will become more common?
or pull cords?
Which means, of course, that even if you aren't using the armour as the cpc you can't bury 16mm² 3-core SWA, or 16 or 25mm² 2-core, unless you RCD protect it.
