should not be a problem providing theirs room to work on it.
a job like can be completed in an hour without draining down system.
This I want to see
yes it will only work short term.
any decent plumber should be able to cut the elbow out
any problems with water in the pipe use a wet/dry vac new section of pipe,elbow etc.
A change of plan then![]()
You will never solder a pipe with water init, not even if you sit there all day.
who said anything about soldering with water in pipe ?
any decent plumber owns a wet/dry vac so no excuse for water to lay in pipe.
don't tell me you can't work on pipework without draining down system.
do you drain down every time you fit a new rad
no one ever had a change of plan.
