- Joined
- 24 Sep 2005
- Messages
- 6,345
- Reaction score
- 269
- Country
Assuming Joe K's data to be correct ... I am not sure exceeding the speed of sound is impossible by a falling person...
Speed of a Skydiver (Terminal Velocity) This draws together some relevant stuff, note, about halfway down the page Joe K and his 0.9 times the speed of sound.... Note also skydiving velocities 'safe' at 110 mph -- Record at 320 mph... two very different 'terminal velocities'.
Falling in the atmosphere, NASA ...
"...Comparing two objects. The higher velocity occurs for greater weight, lower drag co-efficient (more streamlined), lower gas density (higher altitude), or smaller area..."
Comparing a theoretical attempt upon the 'falling man max velocity' with Joe K's achievment .. A good plan might be, to :-
Go higher than Joe's 'float' height (102,800 feet), do more to reduce his 'negligable drag'. ie head first, wearing streamlined hemet, slippery suited body, limbs in line astern...
If all that resulted in a velocity 12% greater than Joe K achieved then the the speed of sound would be exceeded.
Here's Joe K... Hardly assuming the position of least drag... (did it matter at his altitude?)
And a little later, not much change...
-o-
-o-
