Hi
i am after some advice regarding my heating/water system. I have recently purchased a house with a coal fired back boiler that heats the water and the central heating. The heating is on demand via a simple on/off switch on the wall which gets red hot. The water on the other hand will not run hot out of the taps even though i can here it bubbling and have to put the radiators on to disperse some heat.
I have looked in the loft and the airing cupboard. In the cupboard is a quite new immersion heater which heats great and also hot water out of the taps. In the loft i have a maze of pipes. 1 large cold water tank (by the looks of it) and adjacent to that a smaller tank with a ball valve and an inline stop tap between the 2 tanks. The smaller tank is empty.
This problem has only occured in the last 2 weeks until then all ran great apart from the system obviously needing balancing as no pressure in upstairs radiators.
Thanks for any advice.
