Sawing Laminated Wood
19 Mar 2006
Hertfordshire
Hi there.
I have some laminated wood I need to cut down to size. My concern is cutting it without the laminate splintering.
Is there a technique or specific circular saw blade to use to prevent this? i.e. certain make or specific number of teeth?
i assume you mean ply or melamane type wood!!
score to the good side of the cut line with a stanley knife!
or use a sacrificial board on top for a circular saw or underneath for a table saw :wink:
...also, applying tape to the board before cutting it can help a little. The best way to reduce chipping, though, is to use a fine-toothed TCT blade. What saw are you using?
Sorry...laminated chip board.
The sort of stuff all ikea furniture is made out of :roll:
I haven't bought one yet.
Any you care to recommend for a casual, but reasonably decent DIY'er?
I probably will not use it a huge amount so I assume I could get away with a basic one and then just invest in a top quality blade?
how many cuts you after doing !!!
what are you trying to make or adapt!!!
you need reasonable diy skills to cut white melamane to a reasonable standard it chips very easily
I have been cutting away at some old Ikea off cuts for practice wiht an old jigsaw without too much splintering so wasn't expecting major problems with the right equipment
