New wireless thermostat for older boiler
29 Dec 2005
Worcestershire
Hello :)
If anyone is bored and can spare a few moments of their time i would appreciate it.
I have boiler
http://www.ferroli.co.uk/product_documentation/DOMESTIC_ARCHIVE/Domina_80_E_Manual.pdf
and i have now bought a fancy wireless thermostat, which needs 240v to power the reciever.
http://www.sunvic.co.uk/documentation/datasheets/RFP Datasheet.pdf
Here are the pages i thought relevant from the above manuals.
Thermostat
http://i19.photobucket.com/albums/b177/dansarchive/therm.jpg
Boiler
http://i19.photobucket.com/albums/b177/dansarchive/bolier3.jpg
http://i19.photobucket.com/albums/b177/dansarchive/bolier2.jpg
http://i19.photobucket.com/albums/b177/dansarchive/boliera.jpg
It appears that the boiler circuit will only except 14v max via a simply switch type thermostat. I am i right in saying i cannot use this :(
I expected four connections two for power and two for the switch.
Thank you for any advice.
Boiler wants a set of volt free contacts, thermostat has a switched line, you cannot simply connect these together.
You could install a contactor, or see if you can locate a suitable thermostat
Thank you!
yes :D
I thought that some type of relay but i wasn't sure what type.
Never heard the term contactor before :? I will have a look on maplin now.
Thank you.
where do them pins go :(
Isn't there a simple, two wiries in, two wires out thing i can shove in a housing directly about the thermostat?
Great, now i know what you get,
is this common practise though? or am i being a plonker? am i likely to find a another wireless reciever to suit my needs?
All wireless receivers are usually the same. They need 240V on the L & N power in terminals to operate the receiver, then the switch side of the receiver will be connected to the RT terminal block under the boiler which will only send 24V to the switch and back. No need for a contacter in this instance. The boiler is setting the low voltage for you.
I would personally use 5 core heat resistant flex to run from the boiler 240v connections and the RT connections that are next to it.
Keeps it neat.
thankyou.
But im not sure where the swith live wire is supposed to go? theres no reference to one in the manual. Could you point me in the right direction?
Yes i was going to run the mains from the same place the boiler is connected, a fused switch next to it.
Well I'm baffled. I can't see any terminal on the Sunvik transceiver documentation to accept a 24V supply from the boiler.
But then what do I know - I don't even know what "RT" means.
