lead above bay window
10 Jan 2007
trying to sort a problem for a friend , bay window has been fitted with no lead above bay , any alternatives to lead which can be fitted
any help would be appreiated
No lead flashing or no lead cover to the roof?
Flashband, rubber or felt sheet, lead replacement flashing
Was anything fitted with the bay to stop the water coming in?
Whilst you're sorting the lead out, you could take the opportunity of using expanding foam as a second line of defence against water leaks before any sealant or finish is applied to gaps and joins. For instance seal the gap between the frame and wall with foam and then apply the bead of sealant. Fill all gaps you can see before the lead, or whatever alternative is chosen, is fitted.
can explain more about the items and below and which is most cost affective
tyou
