Thanks for the the info. What size sleeving unshrunk is needed to fit over a 16mm cable? 20mm ? or is the size it comes in the shrunk size?
you need to look carefully at the catalog of whereever you are buying the heatsrink from, IIRC it is usual for catalogs to give both the unshrunk size and the smallest shrunk size and they usually give the diameter not the cross sectional area.
Cables are generally measured by the cross sectional of the actual copper conductor so you need to do a bit of maths to convert this to diameter and then add a couple of millimeters for insulation.
