I want to install a 10.8kw mira shower but I'm not sure if my consumer unit is up to the job. I know from reading the other posts about the same topic that I need a minimum of 10mm2 cable and a 45amp MCB. my current shower is a 8.5kw so I'm guessing the cable will need to be changed but i'm not sure if my consumer unit will take a 45amp MCB.
Can anyone confirm if my consumer unit will take a 45amp MCB and if yes where can i get one from?
I'm not a sparky and my knowledge on electrics is almost zero so if you could keep your response in simple terms that would be much appreciated.
