Bell Box Resilience
GJS
29 Jan 2008
Kent
I've heard that a common way to bypass an alarm is to fill the bell box with expanding foam. Is there a defence against this apart from putting the boxes in inaccessible positions?
Thanks.
That was the old fashioned big box with a siren inside. You can't foam the modern type as the sound comes out the back.
.... and if you believe that, you'll ........ anything.
Can I sell you an ashtray for your motorbike, only £87.99 with a free wind guard!
foam is still used thee are "counter measures" but its vare rarrly done on a house
You don't use foam on a modern box - it dribbles down the back. This was proven 15 years ago when it first started. What you do do is know where to aim your battery drill. :wink:
i know where i would like to aim my battery drill - think before you post fool
a handy tip for a burglar, where is the best place to drill the hole? the foam dispencers nozel is about 8mm :lol:
You must think every crook is as thick as you are. If they can hot wire a car they can drill a bluddy hole. :roll:
Just whallop the box with a big hammer, pull away from the wall and stick it in a five season sleeping bag! - just hope they don't have redcare (oh, hello officer) - I love redcare btw, especially when I get it disabled properly through BT and plod turn up anyway....
unless you are a bt engineer you are supposed to inform the ARC you are working on it
don't forget a good set of ear muffs 8)
