Fence posts
17 Apr 2008
Anglesey
5 ft above ground, panels attached, could only dig to about 18 inch, too much concrte below that, all concreted in
there is a slight movement on the post if try to see how hard it set, its only been done a few days
would you say it should be ok, i mean movement of a about 2 mill
Your concrete will have gone hard by now, so either way you'll probably have to live with it anyway!
It seems just the post, not if you push from the bottom, just nr the top
I did think it may just be a bit of movement in the post, sort of flex, yes cheers
