- Joined
- 5 Feb 2006
- Messages
- 156
- Reaction score
- 0
- Country
Hi
Came home from work last week to a complete flooding disaster! Loft, half of upstairs and many items downstairs damaged. Probably can't claim on insurance because it was my own fault - I installed the water cistern a few months back!
Of course I immediately closed the inlet isolating valve and turned on the taps to empty. Then I set about trying to see what the problem was. And at first I really couldn't. No leaks and the valve seemed fine. Then I realised that the problem was one tiny ^%^^%^ing screw which left the ballcock lose on the spindle.
However (and the reason for the post) is that I'm still nervous it could happen again. The problem is that when I installed the tank I drilled the hole for the mains inlet too close to the edge of the tank. This meant I had to bend the long arm that connects the ballcock to the valve. With this bent and the ballcockfree to turn it meant that the ballcock could doubleback close to the valve which basically meant the valve would stay open all the time.
Is it "normal" to ben the arm as in the diagram on occasion and the only reason for the flood was due to the ballcock nut not being tightened? Or should I block the hole with a stopend and fit another valve centrally?
A related question, how dangerous is it to work in flooded area with live mains cable running through?
THanks for reading and I hope our misery made an interesting story for some! View media item 744
