2
2scoops0406
7 pages, quite impressive
Sorry, 8 now
I don't know. Maybe because they are inarticulate fools?
When you strip away the points of connection to expose the topology of the ring you can see that that is how a RFC is wired.My argument was because of that particular diagram and the assumption by yourself that that was how a RFC is wired.
If you have 2 each of LNE singles then you have 6 conductors.All the electricians that I have ever worked with and myself know that a RFC consists of two T&E cables or 2 of each LNE singles leaving the CU and forming a loop that serves all the socket outlets within that RFC.
An interesting philosophical question - is a fool only a fool if he realises it?BAS Wrote:
Are you saying that they know that their text is imprecise, but they use it anyway, or are they just unwitting victims of their lack of proficiency with the English language?
Well - I'm sorry I lost you - I didn't realise I'd written anything too complicated for you to understand.As to the rest of your last post - I think you have lost me - but then I am just an engineer BAS you will have to make allowances.
Why have you not answered a single one of my questions where I've asked you to draw, identify or count conductors?
I didn't say anything about 12 conductors.Don't know where you think 12 conductors comes into the equation?
Please draw me a circuit diagram with 6 conductors in a ring, or a loop starting and ending at the CU.but 2 lives 2 neutrals and 2 earths does indeed make 6 wires per RFC in the CU
What if a conductor wasn't cut at a socket, but just had a section of sleeving removed, and then folded double at the bare length and that inserted into a terminal - would that conductor still be 2 wires?and 6 wires accordingly at each socket.
Ask anyone on here how many lives are in the backbox of a socket on a RFC and they should say two, not one but two.
I would have thought shed be ****ed off having to do the ironing anyway offer to do it for herThere's three in a few of mine - should I pull the third one out?![]()
(might p**s the wife off a bit if she's ironing using that socket...)
The first question I asked you had the drawing of a ring with L/N/E, and I asked you how many cpcs it had. You didn't answer.BAS Wrote:
Because they represent a fatuous argument - I did, in fact, answer but you decided that I should carry out continuity tests because this would some how prove your point.
That the version of a "high integrity cpc" favoured by many here does not comply with the regulations as written.Regardless of all of this - in my first post I did point out that some confusion may have resulted because of the text used. What are you trying to prove BAS
Unless, of course, the regulations do mean what they actually say, and the requirement really is for "two individual protective conductors", i.e. this:you know as well as I do that you have no technical point, no safety case, just semantics.
OK - let's try this again.Bas
you actually said 12 ends at the CU so I ask again where do 12 ends come into the equation?
