1) Were the salts confirmed only in the plaster (which was then removed) or also in the brickwork?
When identifying the cause of damp it is common practice to take samples from both the mortar and the plaster and measure the salt content in both materials.
Softus wrote
That's actually the rare practice; the common practice is to recommend injection based on insufficient sampling and an incorrect analysis.
It is common practice to those who know what they are doing and uncommon to those who are ignorant .
Bit like good and bad plumbers and electricians.
2) Was there a physical gap between the plaster and the floor or did the plaster extend all the way to the floor? What was the floor made from?
Again anybody who knows what they are doing will include this aspect in their diagnosis
Softus wrote
By inference, then, people who don't know what they're doing will exclude that aspect. And, by deduction, since there are people out there who don't know what they're doing, it must happen.
you've answered your own question
...but bear in mind that the plaster can extend down to the floor without any adverse effect on the dpc.
I refer of course to a timber suspended floor
Softus wrote
It can do, but doesn't always. And AndersonC already knows that.
3)Where is the evidence that the injected DPC solved the problem? You allowed the walls to dry out for months before re-plastering with fresh, plaster/sand & cement which commonly contains a waterproof additive. Doing this would probably remove the damp symptoms, in the short term, without the DPC having been injected.
What I am trying to point out is that when a walls is diagnosed as having rising damp, the solution rarely involves only injecting a chemical DPC. Therefore how can anyone be certain that these things actually rectify the problem
Quite simple really if you have correctly identified rising damp as due to failure or lack of a dpc
Softus wrote
That's a huge "if", because one school of thought is that it's simply impossible to correctly identify rising damp as due to a failed or omitted DPC.
Where on earth do you get this information from, if you have read the many previous post you will see it is just as easy to identify rising damp as it is to identify all the types of damp that can affect a building
In laymans terms it's simply a process of elimination
4)I have yet to hear of evidence to show that when the old plaster stays on and the level of ventilation in the house has not changed, the injection of a chemical DPC and nothing else results in the damp problem being resolved
Again if testing for the cause of damp in a property correctly , ie not solely using a damp meter, the results in a case such as you describe will show that only the outer surface of the wall, the plaster is damp.
Softus wrote
Again, your reply to AndersonC's questions are all hypothetical, and have nothing to do with the reality of davebelushi's scenario, which we've yet to hear more about.
Again what makes you arrive at that conclusion, do you have information regarding my occupation , qualifications or experience on the subject. ?
Lack of ventilation will not affect the moisture content of the bricks or mortar to any great degree.
Softus wrote
So, by inference, it
will affect the moisture content to a small
degree.
In your opinion.
