physics puzzle no.2
Yet again you are forgetting one small point.
You can stand the magical object on the belt and hook it up to your winch.
Start the belt up and the wheel will turn at exactly the same speed as the belt, to make any gain from its position on the belt, the wheels have to go faster than the belt.
All the time the speed of the wheels are the same as the belt, the object will not move.
What is so difficult to understand
are you saying the winch will or will not turn?
if it does then the cable will shorten and the object will travel towards it.
so doitall, are you saying the winch will not turn?
It's not impossible to build a conveyor belt the size of a runway. If we assume for the sake of argument that it's possible to build a control system powerful and sophisticated enough to react instantly to the wheels rotation. Then what I believe would happen is that the thrust of the jets engines would overcome the traction of the tyres treads on the belt, and push the plane forwards. If the traction was too powerful to overcome, adding thrust would just increase the speed of the belt, which must be the equal and opposite reaction to the engines thrust that everyone is looking for. Does that make sense?
Nope !! not saying that. :lol:
If you winch the object, the speed of the wheels will be greater than the belt.
Yes sooey that is as maybe, but to make any headway on the belt the wheels will have to go faster than the belt.
For balski.
The speed would be measured at the point of contact between the two surfaces, for example two cars going up the M1 doing 100mph, one has small tyres and one has big tyres, the wheels with the small tyres will be turning faster than the big tyres, but the contact with the road will be the same speed, therefor if one wants to get in front the wheels has to go faster.
The rest is irrelevant
This is a good definition relating to two cars travelling up a motorway but completely irellevant to the plane on a conveyor question.
Define speed in relation to the original question ?.
so, the winch will overcome the movement of the belt regardless of the friction freewheeling going on below the wheeled object?
well obviously it will. there is no resistance 'cause the wheels are FREE- wheeling because they are free of FRICTION. and the winch will meet zero resistance and winch the object toward it.
now apply this to...........
I was agreeing with you, providing the tyres grip on the belt/runway was sufficient, the planes engines would just become a means of controlling the belt/runways speed.
Apply this to what :lol: that the wheel will have to go faster to make headway on the belt.
I agree
Most of what you have written makes sense except you have confused traction with friction. :(
Why are people still going on about this, the question was dealt with on a programme called 'Mythbusters' a couple of years ago.
A jet aircraft was put on a conveyor which was then switched on, the jet then applied forward thrust from it's engines, it took of easily. So that was the question answered.
What, they built a conveyor big enough, powerful enough, and responsive enough to counteract the force of the jets engines. Show us the video of that one.
Not denying that vinty. :lol:
The op added bait into the equation, which make all the difference to whether the plane can reach take off speed or not, and the answer is it cannot.
Lets try again, to take off the plane needs a land speed, to measure land speed its the distance the contact surface moves over the surface that's supporting it.
However in this case the surface is moving in the opposite direction at the same speed as the wheel, whilst the wheel is spinning like mad the surface is doing all the moving negating any forward motion by the wheel.
Make sense or shall we have another 20 pages. :lol:
with all due respect vinty, what has my question got to do with a jet aircraft and thrust from its engines? :?
an object is stood on a conveyor with magical friction free wheels and bearings.
the front of the object is attached, via a cable to a winch.
the winch is anchored to the ground and cannot be pulled free.
the conveyor matches the speed of the wheels.....blah, blah, blah.
you get the picture.
do any of you doubters believe for a second that the winch will not wind the object in, regardless of what the runway and wheels are doing?
the engines react with the AIR. (ref. other post)
It took me a while, and I imagine that most of the posts saying that the plane won't take off are getting confused, as I was, with regard to the wheels / conveyor issue, totally forgetting about the fact that there are hoofing great big engines providing thrust through the air. :)
The conveyor isn't an issue, because an planes forward thrust is via its engines, not it's wheels. If it was by its wheels, apart from the fact that it would be called a car with wings, then the standing still situation would be correct, and in fact a moot point as the question would be something that a 5 year old could answer.
The wheels would, in fact, be turning at the opposing speed of the conveyor, plus the forward speed that the planes engine thrust provided...... its fairly simple really, once you get over the conveyor not being an issue :D
