ABB S191 C10 mcb single phase
Do they look like this?
If so, then they are exactly the same as wylex NSB range MCBs.
Yes they are in a mode dimmer pack 18 of them, they seem quite popular in dimmer packs.
Yours are 271 do you know what is the difference ,I think mine are 6000 rather than your 10000 although they look the same.
Are the nsb still about,do they do a C10, I got a proteus temporary , but I had to cut a slot to fit the busbar up into it.
But not happy with that.
I would like to get the abb, but if not I will change the bank of six on one phase with them to look neater.
It was strange really , they bashed it in a pub breaking the side bit that holds the toggle.
Although the only bit exposed appeared to be the metal toggle hinge ,it somehow shorted to the cover.
I don't know what the difference is between the two models.
I personally would try and source the proper ABB breakers.
Is there a branch of parmley graham near you?
They supply a large range of ABB control gear
The Leeds branch has a trade counter, and are very good. I presume others are the same.
Never heard of them, but can get someone to pick up at heathrow.
Will contact them monday.
Like you I like to keep the same, so thanks :)
