A few arguments against combi boilers;
More bits and pieces in one place (the boiler) thus more to go wrong.
The components are in any system, in a combi they are all in one box, in a cylinder system they are spread over the house. This is a moot point.
And when a combi breaks down, you could lose both hot water and heating. At least with conventional systems you usually/should have an immersion heater to heat hot water in the cylinder, if/when conventional boiler breaks down.
The Gledhill and ACV Heatmaster floor mounted combis have full electric backup for CH and DHW. A small electric instant heater can be in a combi hot water draw-off for DHW backup.
Combi boilers have to raise temperature of incoming mains water around 30-40 degrees in a short time, this uses an awful lot of gas.
Which is not a point.
Imagine you go to the toilet, then use the basin to wash your hands, and you've got a combi fitted. So you turn on the tap, combi fires up. Water is heated as it flows through boiler, so your wasting cold water as you wait for hot to come through.
Dead-leg pipe is the same for a cylinder system. Insulate the DHW draw-off pipe from the combi or cylinder.
Also you are running your boiler at full rate, lots of gas been burnt, then you finally get some hot water. Wash your hands, and turn off the tap. Now the pipe and boiler cool down, and the next person to wash their hands has to go through the same process.
But the DHW draw-off pipe will have hot water in it and the plate heat exchanger will be arm as well. Another moot point.
Standing heat losses of a 150 litre cylinder with 120mm of insulation is 6% over a year. Insulation thickness is less than 120mm so about 8% over the year. Quite significant.
If a system with a cylinder (vented/unvented) is designed and fitted correctly it will give more than ample hot water performance.
So will a well sized combi.
Why do Albion advertise the fact that thier cylinders can be used to improve exsisting combi cylinders? (http://www.albionwaterheaters.com/Superduty.html)
That setup is NOT improving the flow of a combi. It is using the high pressure section of the combi for the shower only and having the cylinder do the rest of the house like a normal cylinder/tank setup.
There are small cylinders that do improve combi performance. These tend to be small thermal stores. Alpha do one.
If a combi is sized properly there is no need for a booster. They are are an after thought for poorly specified combi system
Because combi boilers are useless for multi output hot water systems.
Many combis do two bathrooms.
As a side note, the Albion Superduty Cylinders are brilliant! Worth every penny.
They are good in the right setup, but not exactly cheap.
A direct cylinder, plate heat exchanger and bronze pump heating a cylinder does it in about 2/3 of the time and when the cylinder is empty the boiler will revert to an instant water setup with the boiler providing water heating directly. This is called
thermal layer heating. It heats the cylinder top down. A thermal layer setup is cheaper than many fast recovery coil cylinders and far superior. Many stored water combis use this type of cylinder reheating.
I have used a combis water section to heat an unvented cylinder directly. A Surrey flange on the top DHW outlet tapping and the DHW outlet pumped via a bronze pump into the top of the cylinder. The cooler water returned from a tapping at the bottom of the cylinder to the cold water inlet.When the cylinder was cold the combi provided DHW at the rate in which the burner can provide. The system never runs out of DHW reverting to lower combi flow rate if the cylinder went cold.
The only time I would recommend fitting a combi, is for a single occupancy dwelling like a flat, or a small bungalow.
If the cold mains is good in flow and pressure, A combi should be the first choice in a normal domestic house.
Yes they are great on the central heating side, but then so is a system boiler.
A combi is a system boiler with a water section added. They share most components.
I would always go for recommending a system boiler, and high efficiency cylinder. Usually a Superduty, or a Centre Cyl, which has a 'pancake coil'.
I would go for a combi is the water pressure and flow is good enough, and if not good enough a combi and accumulator.
I know I went on a bit, but thats how strongly I feel about combi boilers.
Hope that helps.
It didn't help at all. It just showed your lack of knowledge of heating systems.
I just had to have some fun with this one.
