I need to move a floor joist about 8cm to make way for a soil pipe which is going from upstairs -> downstairs. The joist is about 3ft long, 7x2 inches, and went from a hole in the brick wall at one end to a trimmer at the other. I've removed the joist and intend to block the hole, then fit new joist with hangers at each end.
Coupla questions:
1) What's the maximum distance a joist can be spaced from the wall? I'm thinking 110mm (soil pipe) plus about 20mm (pipe bracket stand-off), but don't want to fall foul of any regulations.
2) How do I fit a joist hanger to the wall? Screws and rawplugs? If so what length/diameter/type should they be?
3) Do I have to have a stand-off bracket for fitting the soil pipe? I could save some space by just strapping it to the wall, but don't know if stand-off is required by any regs.
many thanks.
Coupla questions:
many thanks.
