I have tried to find out some info regarding private shared water supply and was hoping someone here could advise. I would be really grateful.
Our property is an end terrace built in 1925 marked with an X in the diagram below
As you can see from the diagram , the pipe (appears) to run from the street and along the middle of the space between the two houses, and then branches off with one of the water pipes running through our garden to supply water to four other houses along the terraced row. We were wanting to build a conservatory but don't want to build over the water pipe in case it ever needs to be accessed. We would ideally like to have our own water supply so that
a) we know the pipes won't be lead, b) we are always guarenteed full pressure and c) so we know we only need to worry about our own supply if something goes wrong, and d) so we can ensure the supply is routed around the area where we would like to have the conservatory built.
1) If we had our own water supply put in would we still be responsible for the old pipe supplying the other houses?
2) Also, is there anything we could do to get the old water pipe out of our garden and pay for the water to supply the other side of the terraced row, i.e could we legally get it moved (even if we had to pay for it)?
Yorkshire water don't know or care.
Our solicitor didn't have a clue about the legalities of it all.
Thanks you to anyone who can provide any answers to this.
