Basically, I have the following concealed taps
The left tap is the hot, right is cold. The flow arrow on the hot is on the underneath of the tap (pointing toward the faucet) and the the hot tap opens when the tap is turned anti-clockwise.
The cold tap has the flow arrow on the upper surface and again points to the faucet. However, to get water the lever is turned in a clockwise direction.
To get the cold tap to open when turned anti-clockwise I need to turn the tap around. The means the flow arrow is pointing away from the faucet.
Have I got a mis-matched pair of taps?
