When rewiring an old house - how do you earth split conduits when the conduit finishes short of the switch back box and the top of the conduit is less than flush with the ceiling board ?????/
AFAIAA you are allowed to run double insulated cables through the old domestic installed conduit without it being earthed provided it is not outside the safe zones!
However, if I have been informed incorrectly, I’m sure someone can provide a RN?
If i was to do a rewire to the 17th as of July onwards would i have to earth the old split conduits that are just below plaster depth if i was using a rccd , assuming i am using twin & earth , the existing split conduits would only be used for convenience . Thanks also i have seen twin & earth where both conductors are brown should this now be used for switch drops or is it still ok to mark the blue switch wire with a brown tag.
I too had made an assumption. Mine was that the op was asking the question simply because he thought the conduit required it regardless. On a whim…. as you would say!
jaguar1
In answer to your question, read the posts above and in particular B-A-S’s most recent and consider whether the conduit to be used is in the safe zones?
The Brown twin and earth cable you mention is not a necessity providing you over sleeve and identify the switch wires with brown sleeving at each termination point as you would do now.
