Earthing Split conduits
6 Feb 2006
Hampshire
When rewiring an old house - how do you earth split conduits when the conduit finishes short of the switch back box and the top of the conduit is less than flush with the ceiling board ?????/
Whatever you do you should retain the feeling of joy that you were able to pull new cables through that stuff in the first place... :wink:
Anyway - how about crimping an eyelet to a flylead, and using a pop-rivet to fix it to the conduit?
I know that.
But since you need to earth it you will have to dig a hole and expose it somewhere, won't you.
The conduit is buried top and bottom
AFAIAA you are allowed to run double insulated cables through the old domestic installed conduit without it being earthed provided it is not outside the safe zones!
However, if I have been informed incorrectly, I’m sure someone can provide a RN?
V
Indeed you may, for another 28 days.
And thereafter you may, as long as the conduit is >50mm deep OR the circuit is RCD protected.
But if, for any reason, you actually need mechanical protection to meet a regulation, it must be earthed.
Just as it must now, so when jaguar1 asked about earthing I assumed that for some reason he has to earth it, not that he was doing it on a whim.....
If i was to do a rewire to the 17th as of July onwards would i have to earth the old split conduits that are just below plaster depth if i was using a rccd , assuming i am using twin & earth , the existing split conduits would only be used for convenience . Thanks also i have seen twin & earth where both conductors are brown should this now be used for switch drops or is it still ok to mark the blue switch wire with a brown tag.
Ban-all-sheds, it would seem we are in agreement.
I too had made an assumption. Mine was that the op was asking the question simply because he thought the conduit required it regardless. On a whim…. as you would say! :wink:
jaguar1
In answer to your question, read the posts above and in particular B-A-S’s most recent and consider whether the conduit to be used is in the safe zones?
The Brown twin and earth cable you mention is not a necessity providing you over sleeve and identify the switch wires with brown sleeving at each termination point as you would do now.
Regards
V
