I need to replace a UPVC double glazed sliding patio door with a UPVC set of opening French Doors.
I've had a good look around and found a set at a reasonable price which look good.
My problem is that they all seem to be a standard size which the closest to mine is 1790x2090 , it then says a 5mm gap is required around the edge which basically makes it 1800x2100
I've measured the hole in the wall and it is 1760*2100 so I'm 40mm to narrow.
Do they have any sort of adjustment to allow for this or is it just not going to fit?
If it isn't going to fit can I just make the hole wider by 2 cm on each side, just through the outside brick and then the frame will mostly be hidden on the inside - is that OK?
Any other tips whilst I'm at it?
