I tried to close a service valve on a pipe in the cellar and it sprang a leak, squirting out a fine jet from near the screw. I opened it again and it stopped so i closed it again and i now get a very slow drip. Will the valve actually be closed or might if a broke and stuck open?
Are service valves ball valves? should the screw only turn one way or can you turn them either way?
I don't want to start removing pipe to find the service valve isn't shut off!
