I am having some issues with wiring. A friend replaced a switch in my house with a new one and unfortunately I no longer seem to have a working system. He said it wasn't working but just assumed my bulbs had blown. After replacing the bulbs....I still have no garage or outside lights.
The switch controls an outside light, it receives power direct from the CU before forwarding current to another double switch located elsewhere. The double switch located elsewhere switches on/off a garage light and the outside light.
What should happen is - (a) Single switch turns on/off outside light, (b) Double switch turns on/off garage light and turns on/off outside light.
Unfortunately, no matter what combination i use to wire up the new light circuit, I no longer have a working garage light nor outside light using either the double switch or the new single switch
Can somebody help me. I have not touched the double switch at all.
I have a wiring diagram, although the single switch wiring is show incorrectly, i did not want to just show hanging connections. The crimped "commons" were done previously and are not my doing.
I am assuming (obviously wrongly) that i need to wire L1, L2 and CN as i need a 2 way switch. I used this as my guide http://2wayswitch.com/2-way-switch-wiring-diagram/
Thanks for any help.
*) Note I tried bypassing the switch as a test and wired all 3 wires together. I thought this would send power regardless of the double switching. No success...
**) What would have been the correct way of creating a bypass on the switch are there any techniques i can use to test that power is getting to the double socket. I was going to use a multimeter and a probe, would this be the correct method??
Lots of questions..
Thanks again
Badly drawn wiring diagram
The Single switch L1, L2, CN wiring is guesswork and does not work .....
Inside Single switch
No matter what combination of L1, L2, CN wiring i try using the switch i cannot get a working...
Lots of questions..
Thanks again
