fuseboard in cloakroom
14 Jun 2008
Midlothian
I want to convert a downstairs room into a clockroom, but the fuse board for the property is located in a cupboard within the room. Will this prevent me from doing this or is it ok if it is in a cupboard?
Cheers :?
Will the clockroom (sic!!) contain a fixed bath or shower?
If so, you need to re-site the consumer unit.
If not, there are no restrictions.
Cheers :?
Many thanks, only basin and WC so should be fine.
You might want to consider one of these bad boys then.
Blimey, you're posh!!
You've gone for the flush-mounting version!
I've never actually installed a clock point in all my years.
I have removed plenty though.
Does anyone still use them?
Same, removed a few. Not exactly installed one, but replaced one in a primary school. Its also the only time I've seen one in use!
Duracell have made huge leaps forward in battery technology since then  8)
