Hi All,
Rewire is going well and no problems so far,
I was just after a bit of advice regarding a CH boiler circuit. I'm considering the best way to install my boiler which requires 3A...
Are both the following methods\circuits OK
1) 6A - 1.5mm (non RCD) - 10m run to 3A FCU. Should I use 2.5mm if doing this?
2) I have a freezer next to the boiler. So was thinking it may be best to put this on the same radial as boiler so as to avoid any RCD tripping. Is this advisable and if so would you use..
16A - 2.5mm (non RCD), to Double Socket - then onto 3A FCU for boiler
If the above is designed under 17th i'm assuming all cables have to be run at a depth of 50mm or run in metal conduit (if non RCD). Does this apply if cables are run and clipped to wall surface so they're viewable?
many thanks
Scholesy
