Fused socket for Immersion Heater?
26 Jun 2008
Surrey
Hi, newbie here!
I have just had a new boiler fitted. The plumber would not wire up the Immersion Heater as it 'did not have a fused socket' and obviously could not wire it up as he would then take responsibilty etc etc. All perfectly reasonable given the circumstances.
I like to think i am pretty handy with this sort of thing and would have a go myself. What exactly does he mean?
The Immersion Heater is on a dedicated circuit straight from the CU (don't let the abbreviation fool you into thinking i am an expert lol!). There is an MCB (lol! another one) for it rated at 16amps. Next to the boiler there is one of those large red switches with an LED on (damn! gave it away now!). My question is what else do i need?
Is it something like this?
http://www.choiceful.com/choiceful-id-1613-13-Amp-Switched-Fused-Connection-Unit-With-Neon.html
If so, what should it be rated at?
Most grateful for any advice.
I think you might mean "tank", or "cylinder", not "boiler".
It depends on the rating of that existing switch, but it's likely that you can use it.
http://www.choiceful.com/choiceful-...-Fused-Connection-Unit-With-Neon.html[/QUOTE]
That would replace any existing switch, and it's a perfectly suitable accessory for what you're doing. Personally, I'd buy a branded one rather than the one at that web site.
If you mean the fuse, then it should be a 13 Amp one.
I would also ensure that the flex from FCU to immersion heater is butyl sheathed, not ordinary PVC coated flex.
Yes, that's why I asked!
Some older ones are in excess of 3 kW, hence they were on a 15A fuse with a DP switch, not an FCU.
I think you might mean "tank", or "cylinder", not "boiler"..
Oops. blew it on the first sentence. Yes, i mean Hot Water Tank, sorry must have been thinking of the wife!
Many thanks for the advice. I will replace the existing switch with a branded double-pole switch rated at 13A. I've got some of that heat-resistant cable left over.
Ask for an MK K330-WHI, "13amp double pole switched fuse-connection unit" at your stockist, they cost around five to six pounds each.
For a 3kW (13amp) element, you need a 13amp fuse in it too. :lol: :lol: :lol:
The neon light adds a horrendous chunk to the price for no significant (IMO) usefulness.
